I apply a label to a part: Choose a font, change to engrave, change the size etc.
Then I want to put a label with different text onto another part - I have to go through that whole process again as the Label dialogue box resets to the default settings all the time.
Would it not be better that when I open the Label option again - the settings I used previously are still there? I don’t mind if it resets every time I open the program - but once the program is open the settings should persist between uses.
This would be awesome.
The font I want to use is so far down the list that I need to use an unlockable scroll wheel to get to it and even with my accelerated scrolling it still takes more time than is necessary.
Thanks. The same applies to the hole feature. Constantly have to change settings. If I need a 2mm hole - chances are good I’ll need a 2mm hole again. Doesn’t do any good for the hole options to constantly reset to defaults that mean nothing to me.
