Hi,
Every time I try to figure out the perfect settings to a new resin I need to print multiple parts in multiple different print settings in order to compare them. I would very much like to be able to tell preform to print different models in the same print using different settings in order to save time. of course the layer height would have to be the same, but every other parameter can change, like laser speed and power.
What do you think?
Thanks for the suggestion! The implementation of this could be a bit challenging. We’d need an identifier for parts with different settings and a mechanism for loading settings and applying them only to specific parts. I’ve forwarded this to our software team so that we can look into it.
As far as i understand, this is simply changing the “G-code” for each line (or curve) per part, just as is happening already
