Hi,
I’m starting to experiment with custom resins with our Form1+ but I ran into a problem. When I try to load a custom material file, I get an error saying
Applying Override Failed
Error details:
–><span class is not a valid setting in category
What could be the problem? This happens even with the original material file from GitHub.
Thanks for any advice,
Markus
That’s strange, and makes me wonder if something has gone wrong with the .ini file itself (e.g. an encoding issue that makes Preform think it’s corrupted). I’d like to try to reproduce your error – are you running on a Mac or PC? Can you upload the failed .ini file to this thread for me to check?
Apparently this was just my stupidity.
The file from the .zip package works just fine.
