New Preform version is horrible
Please stop making preform harder to use! This last update is horrible! Is there anyway to use the older version, like (2) versions ago? Why in the world would I want to place things outside the build area?? Everything defaults to outside the build area and will not cleanly snap tp the boundary like before. I place it in the build area and drag it to a corner and its red… this last update is even worse. I don’t want a memory of my last rotation, now I have to do all kinds of math to get it to rotate to the proper degree after setting a feature to the base so it will print without layer lines. I swear every single time there is an update you guys make things worse. Stop messing with preform, or give us a way to use an older version, PLEASE!
You 100% can download & install previous versions of Preform: PreForm downloads and release notes | Formlabs
I think all these changes are great so speak for yourself.
I think you’re overstating this a bit. Models don’t default to outside the build area in my experience, and normal dragging still keeps them within the boundaries unless you deliberately pull them out.
The rotation fields now show absolute angles relative to the model’s imported orientation, so what exactly do you mean by “a memory of my last rotation”?
They’ve also added Realistic View, which previews the printed surface, including layer lines. That gives you a way to judge where stepping is likely to be visible instead of relying solely on particular angles.
When I select multiple models, I’m typically working with 9–10 models at a time. Three might be inside the build chamber, while the rest are scattered throughout it. Our parts require specific orientations for reliable printing, so I can’t simply pack the build chamber and let the software orient everything however it wants.
Here’s the problem with the new absolute rotation behavior. I select a feature to use as the base, and it gives me a random starting angle—for example, -2.7° on the X axis. Now I need to rotate the part 180° on the Y axis. It’s either impossible or unnecessarily difficult because that -2.7° gets carried into one of the rotation fields. What happens when I also need to rotate the part 180° on the Z axis? It becomes a mess.
This wasn’t an issue before. What if I need one model rotated 90° on the Y axis and four other models rotated 180° including the original on the Z axis? Right now, this workflow simply doesn’t work.
If absolute rotation is a feature some users really want, why not give us an option to toggle it on or off? The current behavior doesn’t work for my workflow, and it makes orienting multiple models unnecessarily frustrating. We need the ability to rotate parts predictably and independently, without having to fight the software over the starting orientation.
Proper orientation is critical to reliable printing for many of our parts. Simply packing the build chamber isn’t an option, and the previous rotation workflow worked much better for what we do.
Okay, I agree they should offer both relative and absolute rotation, so you can choose whichever works better for your workflow. But calling the update “horrible” seems excessive. I’d imagine plenty of users prefer seeing the model’s actual orientation, because it lets them set it exactly how they want without having to remember the ten rotations they made beforehand.
I often spend a lot of time finding an orientation that avoids internal supports and needs as few supports as possible overall. Now, when I find a promising orientation, I can simply note the angles, try something else, and return to it later. Previously, the fields kept resetting to zero, so I couldn’t even read the model’s current orientation.
You also mentioned layer lines. They recently added Realistic View, which lets you preview the printed surface and see where layer stepping is likely to be visible. That’s a useful way to check your orientation directly rather than relying solely on angles.
I still don’t understand what you mean about models appearing outside the build area. In my experience, that happens on import when there isn’t enough room for all of them.
You can also disable “Allow models outside the build volume” in Preferences → General.
For rotation, why not suggest an option to choose between relative and absolute angles in the forum’s Feature Requests & Ideas section instead of writing an angry post calling the updates horrible?
And tbh, I actually gave feedback asking for exactly this change to rotation, so sorry about that. Looks like they do listen to suggestions :stuck_out_tongue:
