I’ve heard jewelers are using draft resin to print rings while clients are at lunch. Does anyone have an example of how the quality looks, especially prongs @ 300 microns? Is it worth it?
Draft resin is pretty rough and I’ve had some issues with accuracy… But printing is really fast. I like this resin better for big parts than the small detailed ones.
@fantasy2 is right on about Draft. In general, I’d be surprised if it’s being consistently used for that industry given that the goals of Draft are almost antithetical to Jewelry needs.
That being said I’d be very curious see the use cases you’re referring to if you’re comfortable linking to anything here!
DKirch sent you a PM
