I’ve already submitted a ticket, but you guys on the forums are so quick I figured I’d post this on here and see if anyone has a clue.
I recently got my new order of white resin and a new resin tray. After cleaning off my build platform I tried a print which worked well with the white. Since that print every print I have tried has failed. All of the supports are weak/jelly/not straight and any part of the model that sticks to the supports fails quickly. I checked both of the mirrors that I can see in the machine and both are clean. I switched resin trays to one of my gray ones (cleaning the build platform inbetween) with the same results. I also downgraded my PreForm software a couple versions to see if it was that with no luck. I also placed a piece of paper on the resin tray step and watched the laser during a print and the laser spot looks concise and not blurry. The resin tray seems to peel completely but at this point the only thing I can think it could be is either my build platform or my tilt mechanism. I have a little black plastic dust accumulating on top of my stepper motor that I just noticed but it seems that If it was a peel problem it wouldnt peel at all. Attached are a couple of pictures of some failed prints and some prints I stopped prematurely because I could tell they failed.
