I’ve Check the ID chip on the resin tank it clean so i have no clue why it showing up
Checking the chip for contamination is a great first step but there can be other things that make it challenging for the printer to get a read on the tank. Were you able to try this with other resin tanks to see if those are reading correctly?
I had same issue. It’s prob same one. Email support they have a pdf ready. Basically need or bend back the wires on the Form2. Be careful so you don’t F the machine.
okay i messed with the pins and now it worked thanks
