Sometimes when I import a few objects (3-4) in PreForm and send them to print, one of the object won’t print at all. They’re all small objects and I usually do the one click print. Any ideas?
Are you sure it’s not printing? If it’s trying to print then you may have some cured resin stuck onto the bottom of the tray
In both cases that it’s happened, the resulting print appeared perfect, except with no sign of the missing object, not even a failed attempt.
Now I’m putting all the objects together in one stl file before opening it in formlabs. The first such print is coming out today and I hope/expect it’ll be fine. Just don’t know if I’m doing something or if the program or printer are missing something.
