I have just read through this support document and a couple of things strike me.
1/ There is no mention of filtering the resin. Is this now not recommended?
2/ The document implies that the printer should be run until the cartridge is empty and almost all the resin in the tray has been used. Then it suggests that and what resin is left should be discarded. If this is Formlabs recommendation how much resin will be left in the tray when the printer decides it can no longer continue printing. This would suggest that âhot swoppingâ cartridges, ie printing pieces that take more resin than what is available in the current cartridge and tray, is no longer recommended.
3/ When I was first told of the Form3 it was suggested that it would have the ability to print a mesh over the whole of the build window which would be able to capture any stray debris. has this idea now been abandoned or can we expect to see it enabled in the future?
