I’ve been using Model resin for this print, however it’s not turning out as good as I’d hoped and I’m wondering if I should be using a different resin.
Grey Pro is usually great for those type of models.
Rigid 4000 is the best for getting rid of support marks but it doesn’t fill your fine details criteria.
You can also try Model resin. I personally prefer that to any of the standard resins but it’s not a huge noticeable difference.
Yes, it does. I use it when I need the parts to be a bit more durable but also show every single detail. Think of it as a better version of Grey. The color is a different shade of grey but it’s more resistant and smooth.
As @Eks mentioned, Grey Pro is a great choice for parts that require clean, small details and smooth surfaces. You can also use our material selector to find the best material for your particular needs!
Less brittle and harder to break. For some reason I’m having more luck with that one than with Tough resins especially in longevity but that may just be my case.
We use the regular Grey. Your surface quality is due to the lack of supports. Try filling up the lower edge with tiny supports and your separation lines will reduce.
Hello hoontee,
You and I have the same needs from the printer. I am using Standard Gray v4 resin. If you want, you can see the results here: F-16D Toon and Form3
