Hello! I am going to print a bottle similar to Durable Resin spray bottle that always appears in formlabs videos and website. (PICTURES)
Does that print have a hole to help scape the air on it? Because is going to create great vacuum effect and deformation.
I have an issue with it. I don´t want to put supports on it and the bottle is almost as big as the printing size.
If you have any advice, otherwise I will add some holes on the bottom of the model and close them later.
True, that is another option. Thanks @Randy_Cohen!
What about the print of the picture? Is not going to suffer that vacuum deformation if is printed that way?
I don’t think that this will deform, depending on wall thickness. We’ve printed serveral hollow parts with a similar setup and form tolerances were all okay!
In the videos, we do have a drain hole towards the bottom that gets closed after printing. If you’re printing something similar, I’d go with @Randy_Cohen’s advice and rotate such that the neck is facing the build platform. That orientation might be less ideal for shooting videos but should prove easier to print
