Hi,
I thought Id have a go preparing a model similar to one I have recently sent off to print at company that I currently use until I get my form1. I noticed a few things in the process that I wasn’t sure about and didnt seem to have been covered in the forum elsewhere so I thought I’d try and see if what others thought about my observations, and raise some possible suggestions.
Firstly I’d like to say how nice the interface for the software is. Just as the form1 is a nicely designed product, the software is a great compliment to it. Thanks!
I have been working on a new bottle shape and below are some screen shots of a quick dummy I prepared for this. Firstly obviously the full bottle is hollow so the software has highlighted red areas of overhang if I try to print the bottle whole. There doesn’t seem to be any documentation about this and I see someone else has asked for clarification about what this means, but I am assuming the print will fail as the far side doesn’t have enough support.
I then tried halving the model vertically and this seems to be fine. My concern with this is that others in the fourm are reporting quite long print times and having to print both halves separately seems to be time consuming and also if you look at the volumes, the halved model is 35ml without supports and 70ml with. That means printing both halves will use 140ml for a 70ml print, 50% waste of resin doesn’t seem ideal. As others are requesting internal supports I was wondering if using model surfaces for supports was a possibility too, so you could nest the 2 halves one above the other as shown in a very quick and poorly photoshopped image below.
In terms of usability of the software, I had the following thoughts. I think it might be easier to use with handles for rotating and moving the model by axis. I found it had to finely orient the model with the free rotate style that the software currently has. Also the auto orientate feature doesnt seem to take into account the bounding box of the model and the build area. I would rotate the model and it would snap to orientate but then still be outside the build area. It could also take into account the height off the build platform to minimise support heights, in the image below where the half bottle has support structures, the model could have been rotated flatter to have shorter support heights (and therefore minimise wasted resin), but as mentioned before I was rotating it then finding it was outside the build area on one axis and then going backwards and forwards. Also a cancel button while the software is generating supports might be good as I hit it a couple of times then realised I wanted to change something.
Look forward to hearing others thoughts
Andy
