Hi all
I am not sure, if it’s safe when placing the Form Cure beside of to the two wash tanks filled with isopropyl.
I cannot notice a warm/hot surface on Form Cure, but just want to be sure.
Thanks for any tips
Hello @littleprint ,
Thank you for your question on isopropyl alcohol (IPA) safety. IPA should be kept away from sources of heat when possible; heat will hasten the evaporation and air concentration of alcohol vapors. The Form Wash is designed to minimize evaporation and the Form Cure is designed to heat the air inside the unit, but having them close together will increase solvent evaporation.
I would also reference the Safety Data Sheet for 2-propanol from your provider.
-Jennifer
