Hi everyone,
I had a failed print the other day. While filtering & cleaning the tank, I made the rookie mistake of leaving the print head installed w/ freshly cancelled prints hanging. Of course, they dripped a little droplet of resin onto the glass.
I wiped gently with an IPA-soaked kimwipe and then cleaned lightly with windex. In retrospect, I should have first looked into whether or not there are any coatings on that glass, but the cleaning worked fine and I have produced perfect prints since then.
There is a small bit of streaking from the windex on the glass, but it’s almost nothing.
Does that streaking matter at all, if the prints are coming out perfect? Could it cause issues down the line? Are there better solutions?
Thank you,
Carlos
edit: should have used the search function, oops… For anyone that stumbles upon this in the future, here are proper directions: https://support.formlabs.com/hc/en-us/articles/115000016204. tl;dr: do not use cleaning solutions, only use 90% IPA in order to protect the ARC, use a dry wipe first, then 90% IPA wet wipe, then dry wipe to remove streaks.
