I printed this character model as test and made him hollow inside to use less resin. This model used about 75ml for a size appr. 14cm x 4cm x 4cm.
And the print is really strong. For example the arm is made hollow but will not break easily. I only made the beard, hands and feet full for balance.
As you can see the print is not yet finished. Printed out on 0,05 mm layer thickness so details not at the maximum.
But even like this he looks pretty good and solid.
Kristof Vandebroeck
3D GRAPHIC DESIGNER
KRYSTOV.BE
