I just finished my first few days of working with my new FormLabs +1.
I want to upload photos and video, but I’m not 100% sure how to do it.
So I’m going to simply try it.
I modeled this in Lightwave 3D (11.6), exported as an STL file and brought it into PreForm. I changed the size, and then printed.
I’m not a newbie to 3D printing, I own several (five) Fused Filament printers. But I think I need to expand my skill set, and the FormLabs printer seems like the next logical step.
I’m pleased with my first efforts. I went ahead (on my second print, using CLEAR) and using the highest resolution setting…and the output was fantastic.
I still have a lot to learn about this printer, and how to post-process the prints, but my first impressions tell me that I have just stepped into the ‘next’ level of 3D Printing.
Very Nice print and model! Play around with orienting your model on the build platform though, It seems you’ve used a lot more resin for supports than is actually neccessary. If you orient your model more upright, it should print fine and only use 20% of the support material you’re using right now. Furthermore, it reduces the peel forces on the model as it does not have to peel off such a large area :).
BTW, just wondering. I’m using Lightwave 11.5 myself, but my scaling seems to be off. 1 meter in lightwave is equivalent to 1mm in preform. Do you have the same issue?
Alex, I never had any luck using 'real world measurements in Lightwave. When 11.6 came out, it was one of the things they touted. So after a while I just came up with my own system. I created a virtual ruler and a virtual build box. When I create a new design, the first thing I do is to throw these elements into layer 10 and use them as a background template.
I’m an artist, not an engineer, so CAD precision isn’t critical to me. I created a new build box for the FormLab, and it works fine, but I haven’t done tests to see if the ruler is still correct. Let me know if you want a copy of it.
