Fuse Blast compressor in the EU
Hi,
We bought the Fuse Blast and found out that there is no recommended compressor for it in the EU (like Eastwood 30/60 for the USA).
We have not used the compressor for anything else before so we need an option that fits Fuse Blast just enough for it to work stably.
Another limiting factor for us is voltage input. In our current Office, we don’t have access to 400V, and we prefer to stay on 230V.
Is somebody in EU found a good alternative?
Hi Andr3w_Wy,
The following information is for users who are not in North America or who wish to connect an existing compressor to a Fuse Blast. To match the capabilities of the recommended Eastwood compressor, a user-supplied compressor must meet the following requirements:
  • Free air delivery rate of 12.7 SCFM (360 SLPM), approximately 359.9 L/min at 90 psi (6.2 bar)
  • 4 hp (3 kW) motor
  • 30 gal (114 L) tank
A compressor with these specifications can support blasting up to 60 psi (4.1 bar) with Adaptive Airflow enabled. As an example: Schneider Compressor: Schneider-Kompressor AM B 5-10-500 XBDK Schraubenkompressor 4152009627 | H705107 (German company)
I will also inquire internally to see if anyone has a specific recommendation for Europe based on extensive experience with the machine.Let me know which country you’re from, and I can look into it further for you!
Best regards,
Shiden
