Form3+ /Build Platform 2
the parts that i print directly on the platform are generally almost 1mm thicker, is there a way to get the exact dimensions of the part to be printed?
Hello @ThomasWalder,
Thank you for reaching out - if you’re having a dimensional accuracy issue, you can reach out to Support for assistance.
Regards,
-Jen
You’ll need to adjust your Z compression correction (aka the elephants foot)
and make a small correction in your CAD model. (only if needed)
i get nearly ideal results at 0.30mm YMMV
my best advice is to print a few test cubes at that setting and see what kind of results you get.
