Form2 with 385 nm Resin
Hello,
did anyone try using 385 nm resin on the form2?
I would like to try but would save some time if someone who already tried would just tell me if it is hard or just not possible
The 385nm range is probably very very low intensity on a 405nm laser, so I doubt you’d be able to cure with any efficiency especially without accessing the laser power and cure time settings of the machine… which is not possible with the Form 2.
I wonder if it works the other way round. I mean, 385 nm has more energy than 405 nm by definition, so, even if wavelengths don’t match, will 405 nm resin work on 385 nm printer? Or bond energies are strictly quantified and won’t absorb “bad” wavelength?
