I have a Form1+ with a build platform that says “Rev01” on it. Today I purchased a spare one on Ebay but I later noticed the photo of it shows a “Rev02” label. Will there be any issues using this one on my printer?
You should be fine. My (well the 1 I checked) says Rev 02. The others that I have, I think I have 5 total, all are the same as I gather they are all Rev2. The revision may just be a small design change or FL using a different vendor to manufacturer them. The overall design has not changed from the original build platform from the Form 1. The 1 major change that I noticed is the pin that can now be adjusted to tighten the tension that holds the build plate to the arm. This used to not be adjustable.
-David
