This is too late for the Form 2 (unless someone designs and extension on kickstarter
) though I was thinking it would be good to have some sort of theft prevention on the printer such as a metal ring or something attached securely to the inner frame where you can put a cable lock through it. Has anything like that been talked about?
If you look closely at the back of your machine, there’s a small slot in the middle which fits a standard laptop lock or similar!
Ah ok thanks Matt will check it out
