Form 4B : Enclosure Setup and feedback
Hello,
After months of preparation and various stages, our SLA printing setup is finally operational. Initially, it was meant to take up only a small amount of space, but technical realities forced us to thoroughly rethink our original concept.
Initial setup
Indeed, the odors emitted by both the Form 4 during printing and the Form Wash, which continuously releases isopropyl alcohol fumes (even when closed), were far too unpleasant and potentially harmful to health.
We therefore built an enclosure connected to an air purifier typically used for lasers (xTool AP2), equipped with a significant amount of activated carbon. The air intake and outlet holes were designed to ensure flexibility for any future needs.
Solvents are stored in a dedicated cabinet for obvious safety reasons.
As for the Form 4B, I had much higher expectations and almost regret not choosing a Form 3B+ with its more advanced and proven technology. We are encountering surface finish issues on nearly every printed part, and based on feedback from other users, this seems to be the norm. It appears we’ll need to be patient while the engineers work to resolve these issues.
Fortunately, this machine was purchased to produce our components, and I can adapt the part designs to optimize the printing process as much as possible. However, this adds considerable time to the workflow and contradicts Formlabs’ philosophy of saving time!
For now, I cannot recommend this machine, but I’ll have to make it work for us. I sincerely hope that Formlabs will improve this product, which has great potential but is far from what their marketing suggests.
Edouard
Example of an enclosure printed with One-Click settings (White V5)
Hi @Edouardh,
Your setup looks great! I really like the enclosure you built for the Form 4 and the post-processing station connected to an air purifier.
I would definitely advise you to stop using “one-click” settings on PreForm, as orientation is super important for high accuracy. The algorithm doesn’t fully understand what is being printed and which surface needs high detail, for example, to determine where supports are necessary and where they should be avoided. It’s always better to do the orientation yourself and even manually adjust it a bit to get the best results.
Let’s take an example of printing housings, as shown in your illustration. When printing housings, I aim to keep both parts aligned at similar angles to ensure even tension between the layers. I also avoid long straight lines or surfaces (horizontal to the buildplatform) and try to reduce the cross-sectional area between layers as much as possible.
Here’s an example of how I would orient the housing:
I intentionally place the support structures on the inside, so there are no visible marks (or almost none) on the outside, and the box looks nice and clean once closed. The smaller the layer thickness, the sharper the surface will look. Try to avoid suction cups because the over- and under-pressure formed during the printing process can cause visible layer lines.
If you follow these orientation tips, your results should improve already. If you need more help, feel free to reach out and we can discuss things in more detail.
I’m sure we can solve the issues together and make sure the print results meet your expectations.
Have a great weekend!
Best regards from Berlin,
Shiden Yohannes
Great to see you on the forum Shiden! You are going to take things up a notch around here :slight_smile:
I’ll second Shiden’s comments. For the form 4, consider that horizontally, the pixel structure is square-ish at 50 microns. Yet certain resins allow 0.25 microns in the z direction. Orient your parts to take advantage of that.
And yeah, don’t use the ‘one click’ settings. Over the years, I’ve learned it’s best to manually edit supports once they’ve been placed.
Great setup for an office installation, but I would like to make one comment. Do you have any ventilation in the cabinet where you store the isopropanol? As far as I have heard it can be dangerous to store flammable chemicals in a closed cabinet as the concentration of flammable fumes would be higher than in a normal ventilated room. Just what I have heard maybe good to check.
@Shiden Thank you for the feedback! We’re not really planning on printing enclosures, nor big parts, with the Form 4. It was more of a test for a specific situation, but I ended up printing it with our FDM printer, with much better results in this case.
Regarding manual orientation and support placement, that’s what we were already doing for our parts. I’m indeed achieving much better results, but it involves a lot of trial and error to find the best option. I’ll let you know if we need more assistance.
Enclosure printed on a X1C
@SteamFactoryLLC Good to know for the pixel size, thank you!
@linus1 Thanks! It’s a safety cabinet made to safely store solvent with perforated doors and a retaining tank in the bottom in case of leaks. The isopropanol and other liquids are stored in airtight containers inside.
Technically, OSHA requires IPA to be stored in a certified flame cabinet. If you are in any sort of commercial environment, this is absolutely necessary. If OSHA or the Fire Marshall sees that IPA is not stored properly, you will be fined. There are also limitations to how much IPA can be outside of the cabinet. In our building it’s something like 2 gallons per 10,000 sq. feet.
Interesting! In Europe, fire safety tends to be more about general recommendations. For example, smoke detectors are not mandatory in most countries, just recommended.
We monitor PM2.5, PM1, VOCs, CO2, temperature, and humidity in the workshop. We also have cameras and a smoke/heat detector linked to the fire department.
That said, I prefer to empty the Form Wash into an airtight bucket when I’m not printing for a few days. It feels safer.
Europe takes a much more “too bad you’re stupid” approach since most countries in EMEA are nowhere near as litigious as the U.S. I am a fan of “you make the mistake, you pay the price”. In the case of IPA, if it’s in a sealed container, it’s not going to pose any problems. IPA vapors can be an issue if they are allowed to build up over time, but IPA evaporates very quickly. If the fumes come in contact with arcs or sparks, it will ignite. I assume that in Europe the attitude is, “if you’re stupid enough to have IPA near arcing, sparking, open flames, then too bad, so sad.”
Unfortunately, the rest of the country doesn’t see it that way so we have to conform to strict rules when handling large amounts of IPA.
so, those enclosures on your Bambu were printed flat on the build plate. The enclosures you showed printed on the Form 4 were definitely not printed flat on the build plate. Not a very good comparison. Fingers crossed those snap hooks work for you since they are printed in the weak direction.
Print them directly on the Form 4 build plate with no raft and the print quality will definitely exceed your Bambu’s print quality. Plus, you will have an isotropic print with a better chance your clip will survive.
Yes, it was printed flat on the X1C because it’s the best orientation for the machine and our needs in this specific case. We don’t need this enclosure to be isotropic or stronger—just to have a nice surface finish on the top lid that’s visible and flat (inside and outside) to be installed properly.
If we print this same enclosure directly on the Form 4 Build Platform, it will create a huge suction cup and tensions in the material itself that will probably warp (others have already discussed this in other topics). Even with the recommended orientation, the “test” enclosure printed on the Form 4 warped.
We didn’t buy the Form 4 to print big enclosures, so I don’t mind much—it’s only for much smaller parts.
One of these parts is a round-shaped lid for a small case that needs to be watertight, and I’m printing it directly on the Flex Build Platform for easy removal. Printing directly on the Build Platform without supports (after many trials) ended up being the best orientation, and tensions are reduced in a part that’s only 3 cm in diameter.
Each part has different needs, so I’d say it really depends on the situation :slight_smile:
very nice
Setup update
We recently transitioned from the Form 4B to the Fuse system. Many thanks to 3D-MODEL AG (especially Phil) for facilitating a smooth trade-in process and providing consistent support. We’d also like to thank Idalia, Nils, and Gregory from Formlabs for their valuable assistance.
SLS has proven to be a more suitable solution for our production needs with a significant reduction in manual post-processing. This has clearly improved our workflow.
While the Fuse represents a larger investment, we revised our business plan to ensure long-term viability. The initial results have been promising, and we’re optimistic that this decision will deliver long-term value.
Hi Edouardh,
Thank you for the positive feedback! We are happy to hear that Idalia, Nils, as well as our partner Phil from 3D-MODEL AG, did a great job. Wishing you a good start to the week!
