So it mentions in the instructions of the build platform Flex for the Form 4 that there is a Build platform jig where do we acquire this jig.
Thank you,
Matt Russell
Forerunner 3D Printing
Coopersville, MI 49404
Thank you,
Matt Russell
Hi Matt,
The Build Platform Jig comes included with the Finish Kit (Form 4 generation). You can find more information on setting it up and using it here.
We also have a 3D printable file for the jig that you can print yourself, but please note that the clamp that secures the jig to the table is metal and is not included in the printable version. You’ll need to secure it to the table in your own way—with screws, designing your own jig around the dovetail, or another method. You can access the printable file here: Printable Parts for Formlabs Devices.
so theres no way to purchase one out side of that kit because we already have a Form CureL so no reason to purchase the finishing kit.
Hi Matt,
Unfortunately not, as it comes as a part of the kit. Though the tools included in the kit are unrelated to the Cure L, as the wash/rinse buckets are a manual alternative to Form Wash, or even a separate pre/post wash with fresher IPA. But again, the file to print your own jig is available, you can mount it directly to a workbench or a metal table clamp. I will pass onto our product team that customers are looking to buy the jig separately. Hope this helps!
well thanks anyways were are going to buy the kit because we can use the tubs with our Loctite resins
