Form 3 works with Clear V5 resin, it even detects it
So the form 3 recognises clear v5 resin, the 5v resin even comes with a card for the form 3 pump. So why does formlabs not allow me to use the clear v5 resin on the form 3??
I have already proven you can print the clear v5 resin on the form 3 and it works without issue.
So formlabs, why do you not allow me to use the clear v5 resin on the form 3???
Thanks for your message! While the printer is able to detect resins, whether printing is possible depends on the availability of print settings. Since Clear Resin V5 is a material formulation optimized specifically for the print engine of the Form 4 generation, we don’t have print settings for it that are compatible with Form 3. For this printer generation, the material with comparable properties is Clear Resin V4.1.
i am curious if you actually read my post. or checked my post history, or profile.
I have a form 3 profile for clear v5 resin that works on the 3l and the 3b, I have tested it extensively and it works fine. The ONLY reason formlabs does not allow use to use the new resin is $$$$$$$$.
