Thank you @lepold for your reply. Yes, my printer is missing the second connector where the coloured wires from the tensioner are supposed to plug in. I don’t think this depends on the specific model, but rather on the year of manufacture. Mine is a Form 3B, but the photo showing the dedicated connector for the coloured wires is also from a Form 3B.
My original plan was exactly what you suggested: to get the tensioner from a Form 3L and connect only the red and black wires to the same points where the corresponding wires from my original tensioner are connected, leaving the brown, green, blue and purple wires disconnected. I would have to see what happens, I’ll never know unless I try.
For the time being, I’ve managed to find a temporary solution because another user kindly sent me a used tensioner identical to mine, although they couldn’t tell me whether it was working or not. I replaced mine with it and finally managed to print again, but error 137, which is also related to the tensioner, has appeared. I tried printing again and the print completed successfully, but I can’t rely on this motor for much longer. It could stop working completely at any time.
However, I’ve managed to find a generic tensioner online that is exactly the same as mine, including the 2 cables (red and black) connected by a yellow resistor, and rated at 80 RPM. The only difference is the shaft: it isn’t toothed but has the usual round shape with one flat side, like most generic 37 mm electric tt motors. I don’t think this will be a major issue. I’ll try replacing the shaft with the one from one of my original tensioners. Alternatively, I could use the shaft from the Form 3L tensioner, although I would obviously have to shorten it because it is longer.
It’s outrageous that Formlabs’ response is essentially to tell you that your printer is no longer worth repairing simply because they don’t recommend replacing the tensioner, claiming that the procedure is too complicated. It’s only complicated because there are no clear instructions or proper tutorials available. I managed to disassemble all the necessary parts on my own, figuring things out as I went along. With a proper guide, the whole process would have been much easier. Anyone with a little patience could do it.
The truth is that they don’t supply a replacement part that costs around € 10, they don’t even seem to know how their own machines are built internally, and they have every incentive to make you discard a perfectly good printer so that you’ll buy a new one instead. Well, after this scandalous experience, I’ll think twice before buying another Formlabs printer in the future.
If you could take a photo showing how you connected everything, it would still be extremely helpful, not just for me but for anyone else who runs into this problem, which I’ve learned is quite common. Taking the photo should be as simple as removing the rear cover. It’s just 4 screws and about two minutes of work.
Thanks again for your help!
