Fogging under optical glass
I’ve got a little fogging going on the left underside of the optical glass of my Form 2. Plus a couple tiny dust particles that somehow managed to find it’s way onto the underside of the glass. I haven’t found any web page or instructions to show how to get in clean the underside of the glass. Could someone point me in the right direction? It would be much appreciated!
Hello, I got this issue few month ago. Don’t worry it’s not too hard to fix, but i lost the explaining Pdf :frowning:
To summarise you will need to remove the frame+glass part with Allen key (size 2 i think). You can see these screws on left and right of the glass. Depending of your form2 Model, the 2 left screws are a little bit hidden, so you will need “Ball-ended” Allen Key for it.
Keep a Pec-Pad or something similar on the glass so you will not scratch it if the allen key slips!
Then you just have to remove the glass and clean with IPA alchool and Pec-Pad and put the part in place.
I think you’d better contact support so they can send this pdf with exact way and agree that you do this repair yourself, they are very quick!
Our support team is going to be best suited to help out with this and we’ll work to identify the cause and go through steps to get it corrected. I’ve gotten in touch with our team and one of our members will be in touch with you over email to help out.
