Flat spots when printing on build platform
Hey guys, I’ve got a quick question I was hoping to get some help for. When I print models directly on the build platform they have a flat spot where they are touching it.
Is this a normal thing when printing directly on there, or is there an offset/adjustment I need to make to avoid this?
Thanks,
Gareth
Flat%20-%20Print%20Issues-resize
form 2 compacts the first 0.5mm to ensure is sticks to the build platform.
I’m sure this is what will be causing the flat spot.
don’t this the shape of a ring in that orientation will work for building directly on the platform as the curved shape gives a very limited contact point. I believe building on the platform is much more suitable for part with large flat features
The printer uses a high exposure for the first layers to help with adhesion which is causing that. for a ring, you’ll want to start off with one point about 5mm off the build platform.
