Hi,
Is it supposed to fill the tank super slow, the stream of resin is about 1 mm in diameter.,
I emptied one bottle manually into the tank.
Hi,
you likely have to re-slit the rubber spout on the bottom of the cartridge, DO NOT REMOVE IT, (you’ll make a mess like I did) carefully re-slit the spout w/ an exacto blade, not too much tho, else it will keep dripping (yes I made that mistake as well)
