Failed print sticks to tray
I have printed this ring top 3 times. 2 failed and a flat version came out but had ,lines across the background. When I printed it at an anfle (see pic) it stuck to the bottom of the platform twice! brand new tray and cartrigde. Thoughts on how to spur or change so it does not fall off theplatform?
meant to say it does not stick to build plate
From the pic, between the two edges you don’t have much supports, while peeling off it may just collapse. Does the base stays on the build plate at least? Or really nothing adheres to it?
the purple castable does not want to stick at 50 microns, ive tried multiple times and it just wont stick. move it up to 25 and you wont have any problems
strange thing is that one print stick and the other did not. the print that was flat stuck but had lines thru the lettering. the angled print fell off. I will try at 25 microns. nothing stayed on the build plate for the failed prints.
i will try it at 25 microns tomorrow and see if that works
well the bottom right corner doesn’t have a blue checkmark, by looking at that I would guess you would have problems.
i will try again and see if I get the checkmark. I print all the time with success when it says it will not print… will look thru the layers and see if there is a breakdown somewhere. thanks for noticing that
, [quote=“rji5668, post:8, topic:20215, full:true”]
[/quote]
oh I never print without the checkmark.
