- I run the Form1 in a lab environment, and there are often electronics and “things” floating about.
I don’t yet do a lot of large, over night jobs, but my experience with a previous spill incident on another SL machine led me to install a leak detector next to my Form1, just for some peace of mind. Currently, I’m using this one, since I already had it floating around as CRUFT:
However, there are cheaper units you can get, like this honeywell:
I’m not saying that anyone should get one … but I like the idea of detecting a possible spill as early as possible, given they can be time consuming to cleanup … and if you get resin down below in the Form1, it’s even more so. Plus the finishing kit … it would be bad if IPA spilled and you did not notice it … when you’re dealing with the Form1, you’re dealing with liquids. My circumstance is a crowded environment, so I thought it might be worth it. If you’re in a busy, shared environment where things get moved around a lot, it might also be something to consider.
- Could a leak detector be added to the Form? I’m sure it could … perhaps mounted down below? … or on the under carriage near the tank somewhere … tripping the resin might pause or shut off the bot, maybe … or maybe it’s just an audible notification. Would it be worth it? Given that the Form1 does not yet have a reservoir tank, and the likelihood of a malfunction is low, perhaps this is not warranted … that’s one for purpose the Form team to consider or disregard based on what’s in their db of tickets. I’ve seen some stuff, but not enough to warrant a feature add.
Just some thoughts from an operator.
I’d be curious to hear from other operators about any significant spills they’ve had with SL bots, either due to operator, machine, or accidental instances.
-sj
