Hi all. I’ve been working on a method to produce electronic circuits on 3D-printed parts. The basic idea is to print the part normally, put it into a standard CO2 laser cutter, which patterns the surface, then dip the part into a copper plating bath. There are commercial techniques similar to this, but none that allow the use of common CO2 laser cutters. I was able to do 0.5mm pitch no-lead and 0402 components, and the method also provides plated through-holes with no additional steps. One remaining problem with this method is that the copper adhesion to the 3D-print is really good until the soldering flux touches it, at which point, adhesion is poor.
Let me know what you think. The next steps are to fix the flux/adhesion issue, and also start exploring 5-axis control to make circuits on contoured parts.
