Drainer Hook for Build Platform 2L
Hello guys
I have a Form3L and 2 build platforms, the conventional and the 2L (flexible).
My question is about the draining hook, it fits perfectly in the V1, but it doesn’t with the 2L (my main one). Also the 2L is considerably heavier, is there any problem/risks in using the build platform 2L in this hook that seems to be designed only for the V1? When I print large parts it warps and seems that will brake.
Good Morning!
I do not recommend using the hook for the heavier build platform, as this could possibly end up breaking. Since this was meant for only the non-flex build platform , I would stick to using it for this build platform only. If you want to keep your flexible build platform latched into your Form 3L for a little longer to let any resin drip before removing your completed model, this would be a better solution to make sure this hook stays intact.
Thank you, unfortunately even if I let these parts for hours, they’ll only drain properly when they’re in the hook. :sweat_smile:
Is it possible to change this hook for an Aluminum / Steel version? Obviously I’ll manufacture it and I’ll ask help just to disassembly it.
Hi, you can absolutely replace the hook. It just locks in there by twisting. You should be able to remove it and have one created for your needs in a material that would work better for your build platform.
Please let me know if you have any issues removing the current hook.
