Distance to Wall
I’m using Preform with our Fuse1+ machines and have noticed that the ‘Distance to Wall’ value is defaulting to 0mm instead of 5mm like it used to. Does anyone know if there is a reason for this?
I noticed the same thing after the last update. I always set it to 3 mm and haven’t had any problems with that.
Thank you both for flagging! I’ve check with our team, and this seems to be a bug - a fix is already in the works!
And I actually thought it was intentional :wink:
We always print with a 0mm wall clearance. We did this even before the update that apparently set the default value to 0. With our workflow—in which we don’t reuse surface armor and our Fuse is very well calibrated—this is easily possible.
