Hi folks.
I’m using a Form 2 and I’ve had a quick look at the spec sheets, but it’s practice that tells you the most and not wanting to waste a load of material I thought I’d ask you folks here…
As well as the inevitable X-Wing, Tie Fighter and Homer Simpson I need to print prototype parts where dimensional accuracy is the most important variable. How do the modelling black/grey stack up against the pro resigns, the tough and the durables?
As with the older FDM printer do I need to consider any shrinkage/bloomage trough the curing process, or things pretty static? Again, do the modelling resins behave the same as the Pro?
Many thanks peoples.
