Differences Cure 1 and Cure 2?
Hi,
I’m currently using a Form 4B with a wash station and Cure v1 curing station. Other than faster heating and curing times, is there any difference between the Cure v1 and Cure v2 that would make it worth upgrading?
Hi alfonsvh, another factor to consider can be the part dimensions - if you are printing parts in the max. dimensions of the Form 4B, the Cure V1 might be too small, while they will fit into the Cure V2.
It also simplifies the workflow with pre-programmed cure cycles, including optional low-warp cure settings for Tough and Durable resins (which cures without heat).
I hope this helps!
