Delfin Vacuum Pre Separator
The Delfin vacuum is reliable and high quality, it does a great job of keeping things clean and powder where it belongs, however the filters are fairly expensive. It makes sense to use some type of pre separator to remove the bulk of powder before it reaches the vacuum in order to preserve the filters for as long as possible.
My original setup included a 5 gallon bucket mated to a plastic cyclone separator. This apparatus worked well but had static buildup issues that necessitated the installation of a grounding wire throughout. I further discovered these consumer grade cyclones, while cheap and fairly effective, still allow a good quantity of particles to pass by, which also contribute to clogging the filter. I think they are mostly intended for sawdust.
I elected to bite the bullet and purchase the Delfin cyclone setup. It is not cheap, but it does a really good job removing the powder and its fully grounded throughout, including conductive hoses, paint, and a dedicated ground that attaches to a hardpoint on the cyclone for grounding to my facility (basically the same as what’s on the vacc). The result has been more effective powder separation and I no longer worry about frying my very expensive 3d printers and/or their support equipment.
Here is the Delfin part number for the cyclone: ESD.SEP.0467
If you order this and purchase hoses, make sure they are conductive for static dissipation.
You will not believe the cost of this item, but it has been worth it for me. In the long run it will pay for itself in avoided filter replacement costs and potential static electricity induced damage to my machines.
That’s a really solid setup, and your reasoning makes a lot of sense. Delfin vacuums are excellent machines, but those filter costs definitely push you to think long-term about protection and efficiency.
Your experience with the DIY bucket + plastic cyclone mirrors what a lot of people run into. They work okay for coarse stuff like sawdust, but fine powder is a different beast. Static buildup alone is a headache, and even when grounded, those consumer cyclones just aren’t designed to catch the really fine particles that end up loading the vacuum filter anyway.
Going with the Delfin cyclone sounds like the right call, especially in a 3D printing environment. Proper grounding throughout, conductive hoses, and a dedicated grounding point eliminate a lot of risk, and the improved separation means your filters last longer and performance stays consistent. When you factor in the cost of replacement filters—and the potential damage static could cause to printers and electronics—the higher upfront cost actually seems pretty justified.
It’s one of those upgrades that’s painful at first, but once it’s in place, you stop worrying and just get on with the work.
