Delfin MTL300 Vacuum Bags
We acquired our Fuse 1+ 30W with the Delfin MTL300 Industrial Vacuum (just prior to the newer powder vacuum becoming available). Wanted to ask users in the US where you may be sourcing your replacement bags?
Hey @greasemonkie thanks for reaching out! We recommend you get them directly from Delfin.
It requires you to make an account (free) and then you can order directly from them. Check out our Formlabs Approved Distributors list for all suppliers we recommend.
You might consider adding a cyclonic dust capture system in front of your vac. This will greatly prolong the life of your bags.
Hmm, do you have a link to a cyclonic dust capture system? I just go straight to the vacuum bag so if i save a bit on that cost it would be great.
I use this mated to a 5 gallon bucket: https://www.harborfreight.com/cyclone-dust-separator-kit-for-5-gallon-buckets-57194.html
Most excellent. thx.
Just to add to my recommendation, the cyclonic capture system may generate quite a bit of static electricity so proper grounding of this apparatus is necessary to avoid equipment damage.
Yeah proper grounding is 100% needed. Thx
I have a question about this, how are you grounding your capture system exactly? Beyond grounding the the Delfin vacuum?
I ran a braided copper cable through the hoses and attached the end to the grounding point on the delfin.
