Cure L: Custom Profile Names / Pin Faves / Enable Reordering
Currently, the Cure L machine is feeling dated due to the lack of profiles for Grey, Black, White V5. Tough 2000 is there, but requires repetitive scrolling to get to it.
Request 1: Enable naming for custom created profiles.
Request 2: Enable pinning of frequently used resins (~4) to the top of the list
Request 3: Enable reordering of pinned resins
Request 4: Enable power savings mode or sleep mode
Hi arvinabadilla,
Thanks for reaching out! There should be profiles for the Standard Resins V5 on the Form Cure L actually. It could be that a manual update is required to make sure your device is on the latest firmware. You can find the firmware here and instructions on the manual update here.
I have also let the team know about your suggestions.
I hope this helps!
Thank you, I also added power savings mode as a feature request. Currently the Cure L has noisy 24/7 fans and it would be nice to be able to cut the fans in power saving mode.
