I recently had this print come out where it seems to be pulling away from the build plate and cracked along certain layers. I was using ClearV4 and this is the first time this has happened on this printer. Is there any solution to this. Images attached.
Hi bkjensen,
For this, the best way to get support on this is to create a support case with our support team, as there can be many factors causing this. I would make sure the logs are up to date, and to also provide the form file and the team will investigate and provide additional insight.
