I watched the video HERE, which @amosdudley introduced us about the ceramic resin. He mentioned we should apply a clear film to the orange cover in order to prevent spillage of the resin to the Form 2, what clear film is he mentioning here?
Also, @amosdudley also recommended us to print a splash card to further protect from resin spillage from the resin tank, do any of you have the splash card stl file?
It is a clear plastic film with adhesive on one side. You can use scissors or a hobby knife to cut it to size and apply it to the inside / outside of the cover, wherever you’re worried about drips (the front and sides are most likely).
I can’t find a way to set up the printer for ceramic resin printing using the 50 micron setting
and only have access to 100 micron. It says in the technical spec sheet you can use both.
Am I missing something?
