Hello everyone,
Here is my problem.
I am a jeweler and I use a formlab Form2, resine blue castable.
When I print engraved pieces with text (example: medal, alliance), and cast, the surfaces stand out well, but the engravings, clogged.
I clean them with IPA, rinse, and UV.
Do you have the same problem?
Do you have a solution?
Thanks in advance.
Thomas.
You have to offset the edge of any feature by about 0.1 mm, because the laser is centred on the line of the edge.
