The more I print with Form1 the more it seems to be nice to have a post curing chamber. Usually the part requires some time to dry IPA and post-cure before that, I can scratch or even destroy it with not much force.
I’ve been googling for a week or so but today I found some posts on the forum for UV lamp curing with sterilizer(which uses shorter wavelength-with divided results) or nail curing devices(cheap, nice with hot air but small). And on this post ( https://support.formlabs.com/entries/24632602-DIY-Post-Curing-Box) Bryan had a very similar idea with mine having timer and turntable to evenly cure and prevent overcuring.
I’m thinking to build a post curing chamber(which many industrial SLA manufacturing process includes) with 405nm leds with turntable, fan and temperature controlled heater with timer. I assume most of the people on personal 3d printing industry are tech savvy to build their own curing chamber with functions stated above, but rather than collecting all the parts and making your own laser cut drawings for casing, it’d be much easier to have it from single source.
My questions are as below;
Do you feel the need for post curing chamber which could finish the part in less than 30 minutes rather than letting it sunbathe for hours?
Are you interested in purchasing a kit that does question no.1 for around $100?
I’m probably build it anyway since I need it some parts are already purchased, and maybe/probably open up under CC or similar license in return for what I have taken from the open source community.
And I apologize for not making it clear if I have, I tend to wander around when I explain something .
