Hi Dudemeister, have you tried using anycbic resin using openFL? I haven’t had any luck with getting the raft to stick to the plate. (I have moved the home position of the plate from +1 to -1) What laser speed and power combo would you suggest? Knowing it is 6-8 times faster is a big help for my next experimental session!
I have used some “godsaid” resin (Chinese) with the FL black01 resin type and it did stick and printed fully but was rough - not sharp features - hard to describe as I don’t know what over and under exposed looks like really. - I guess over exposed! Thanks for any help you can give. Cheers
