Just want to know your thoughts… This printer was announced at Euromold earlier today
specs according to 3ders.org
- Net Build Volume (xyz): 43 x 27 x 180 mm (1.69 x 1.06 x 7.086 in)
- Native Resolution (xy): 56 micron (effective 585 dpi)
- Layer Thickness: 0.03 mm (0.0012 in)
- Vertical Build Speed: 14 mm/hour (0.55 in/hour)
- Material: VisiJet FTX Green
- Material Packaging: All-in-one cartridge with built-in print window
- Post-processing: Built-in UV Curing Station
- Software: Network connection, Windows-based OS, Built-in STL verification, Automatic and optimise
- File Input STL
- Electrical Requirements 100-220V 50/60 Hz
56um at xy is pretty good, I don´t own a Form 1 (hopefully they will send it to me i Sweden in January) maybe you guys could compare the accuracy to the Form1. I know for a fact that a normal hair straw is 50um, should be good enough for jewellery making and dental work. And the price is affordable
