I am currently working on digitally laying out equipment in our office space (a virtual floor plan / digital twin–style layout), and I was wondering whether there is an official or community-shared 3D model of Formlabs printers available.
I fully understand that sharing detailed CAD data containing internal structures or mechanical components could raise concerns around IP protection and information leakage. That said, for our use case, we are only interested in a basic exterior / envelope-level 3D model (for example, overall dimensions, outer housing, and rough geometry), purely for spatial planning and visualization purposes.
Even a simplified model (STEP, STL, or similar) representing only the external form factor would be sufficient. If there are any officially provided assets, recommended sources, or policies regarding this, I would really appreciate being pointed in the right direction.
Hi! Which printers are you looking for? I don’t believe we have a public repository but we have space planning models usually by request. Let me know and I can have someone reach out to you with them.
We went through this exercise when planning a small room we had available for SLA printing. We used the dimensions from the webpages and user manuals of the printer, wash and cure station to create basic blocks. I’d definitely love more discussion about printer space/room planning on this forum!
If you’re also doing SLA, don’t forget about storing cartridges, resin tanks and containers of saturated solvent solution. I’d rather not share our models as they might have some inaccuracies and we don’t have a model of the newest Cure. The power blocks of each device will take up some space as well. Easy access for throwing out tissues when cleaning the build plate/work space is useful!
@henryqiu I personally would be interested if you could share the space planning models of the SLS ecosystem!
@henryqiu Hello sir, I need a 3D model of the form4L, but not the space planning model but the printer itself. I want to add it to a fab lab design requested by a client and they’ve bought 3 printers and they want it added to the design. is it possible to provide such file? thanks!
Hi henryqiu,
do you have a 3D model of the Form Wash L V2 that you could share?
In general, it would be very helpful if Formlabs could provide simplified 3D models and/or 2D drawings of their equipment. These would be especially useful for workspace and layout planning.
For the Fuse setup, Henry’s post #5 already includes STEP downloads for the Fuse 1, Sift, Blast, build chamber and stand, as well as a Form 4L STEP. They’re described as space-planning models, so they may not have the detail you’re after. For the Form Wash L V2, Sophia’s post #13 has an STL, not a STEP. Which features are missing for your layout? That would help separate a request for another file format from one for more detailed geometry.
The Fuse setup is the Fuse 1, not the Fuse X1 (the new large format SLS printer they recently released). Also, if you look at the Form 4 model and the Form 4L model, you will notice that the Form 4 model is almost like a final production model. Moving assembly, separate parts, and even the tray and cartridge. the Form 4L model is just literally only use for rough dimension, no detail. Same with the Wash L V2. I just like to have really detailed models in my setups when I am designing so that is why I ask. The other models are beautiful like the Form 4, Cure L V2, Fuse 1, and the sift and blast.
Thanks for clarifying. I misread Fuse X1 as Fuse 1, so those downloads don’t answer that part of your request. You’re looking for detailed models for your layouts, rather than just overall dimensions. My earlier pointer didn’t resolve that, and I don’t have a verified source for those detailed files.
