For the first few mm of your print, you only have one support holding onto the part. That means that part is wobbling during the peel cycle and may not return to the intended position for the next layer. This shift means that the next support (several mm later) cannot connect to the part, and an “explosion” failure is seeded. What you’ll want to do is add 3 additional supports in a triangle right around the first support. See the image I uploaded here, in response to a similar issue.
