We found another one in the dashboard.
Our Form 3 does not seem to report which kind of resin is in the machine. Three prints ago we did a high temp V2 print. Then a lot of clear V2 prints. The online dashboard still shows high temp as active resin in the printer.
Starting with PreForm 3.3 you should be able to get Form 3 print times if you hover and press the small circular arrow.
If you have the latest firmware installed on Form 3, it should be correctly logging the material info to Dashboard (we fixed a bug in the Dashboard logging awhile back).
