Is there a software for free which allows you to compare the accuracy of dental Models! I often see pictures with a color imaging from green to red. Thanks!
Gibt es eine free Software um die Genauigkeit von Modellen zu überprüfen? Man scannt dabei 2 Modelle ein und eine Farbcodierung zeigt die Abweichungen an. DANKE!
There’s an earlier thread on these visualizations here! The images on our site were done using a program that came bundled with our 3D Scanner but GOM Inspect can be used as well.
I tried Gom inspect and also Volume Graphics but both don´t support dcm. oder stl. files? So I can´t import the models scans from 3shape. It´s necessary to convert the stl. oder dcm. file into an other?
thanks!
