Has anyone tried putting UV lights into the lid of a Wash?
There are lots of suggestions on the internet, mostly from hobbyists with cheap Chinese printers, that say that IPA can be cleaned by just placing the cleaning bucket out in the sun. I’m a bit sceptical of this myself because every time I’ve tried it the IPA turn into a solid gel. But I suspect that if there was less than a certain about of resin dissolved in the IPA it would tend not to form long crosslinks which result in a gel but the small clumps that people are reporting.
So the idea is that the IPA in the Wash should be irradiated with UV after each wash so that any dissolved resin becomes solidified and falls to the bottom of the tank. The tank would still have to be cleaned out to remove the resin, but, if this works, it would massively extend the like of the IPA.
