Visual indicator for "out of bounds" in printer build envelope of an object
Please add a visual indicator that instructs users that the print will be out of build area volume interactively … not popping an error message after it happens. It saves the user time if it happens interactively. A color code, or model rendering difference in edges that are outside the boundary of build would work.
This a good idea!
Perhaps a planar, top-down image projection in a bright color could be an easy solution ( I haven’t a clue what it takes to implement into the software)
